Tyres Alignment
amserve
Hi all
Recently noticed I am driving straight with the steering wheel pointing at 2 o clock!! I dont understand because when parking the car the steering wheel and tyres are apparently straight, but on a straight road tyres are going straight if my sterring wheel is towards the right :o
Am taking it to the tyre shop tommorow, will that sort it or will it be impossible to be reset the alignment ? could it be something other than tyres, like steering components ?
any suggestions welcome....
Check tyres first - low pressure, or uneven wear could cause this.
Then, consider a full wheel alignment - not just tracking - if you have uneven wear. That will identify whether the fault can be adjusted out.
Typically Mr T charges 70 + VAT for this including any necessary adjustment. Other places may be slightly cheaper or more expensive.
