93 Camry Fuse Locations
wardfam
Don't know the camry specifically but check the inside of the fuse box cover, most manufacturers mark the fuse locations on the lid. If nothing else has stopped working its probably not the fuse thats your problem, its highly unlikely that the back up lights have their own dedicated fuse, it will control several other things too. Assuming the bulbs are good the next most likely fault will be the back up light switch on the gear box
