Auto-locking
nordberg
On my Celicas there was a facility to auto-lock the car when the ignition was turned. Is there a way to do achieve this on the (2003) Corolla?
Found elsewhere:
1 Start of procedure
Alarm system has to be in disarmed state, and all doors closed.
2 Enter programming mode
For remote control key cars:
– Insert the key into the ignition.
– Turn the key to IG ON position 5 times (IG OFF -> ON) within 20 s.
– Final key position: IG ON, Alarm status light (LED) is on for 30 s.
For Smart key Entry cars:
– Have the smart key inside the vehicle.
– Without pressing the clutch, press the start switch until IG ON status has been reached
– Final start switch status: IG ON, Alarm status light (LED) is on for 30 s.
Note:
– If IG OFF-> ON is operated more than 5 times, you have to withdraw the key from the ignition
and repeat the above procedure.
EN VSS1
3 Select the programming mode
Within 30 sec, select the programming mode by performing the following number of door open/
close operations; (counting the number of closures).
One: Buzzer ON/OFF (see paragraph 2.8)
Two: Automatic doors lock ON/OFF (see paragraph 2.3)
Three: Alarm memory confirmation (see paragraph 2.5)
Four: Installation confirmation (see paragraph 2.9)
Five: Additional car horn ON/OFF (see paragraph 2.6)
Nine: Passive arming ON/OFF (see paragraph 2.4) (Not available for Belgium).
4 Confirmation of programming mode
Turn the key or press the start switch to reach the OFF position, (IG ON -> OFF) to enter selected
the programming mode.
Note:
– The selection is confirmed by hazard lights flashing and the buzzer beeping the same number
of times as the above number of door open/close operations.
– To restart from point 3 you have to turn the key to the ON position (IG OFF -> ON).
Now you must choose the functionality you want.
5.1 Modify the settings
Close door count:
One: Buzzer ON/OFF.
1) Open and close the door one time within 30s (Alarm status light (LED) will turn ON).
Once: Buzzer OFF.
Twice: Buzzer ON.
2) Turn the key (IG OFF > ON > OFF).
The LED will turn OFF and the hazard lamps turn ON the same number of times as the
3) Turn the Key to ON within 30 seconds to restart from point 3).
Two: Automatic doors lock ON/OFF.
1) Open and close the door two times within 30s (LED will turn ON).
Once: Automatic door locks OFF.
Twice: Automatic door locks ON.
VSS1 EN
Five: Additional car horn ON/OFF.
1) Open and close the door five times within 30s (LED will turn ON).
Once: Horn OFF.
Twice: Horn ON.
Note:
– This activation is not possible on all car models.
Nine: Passive arming ON/OFF.
1) Open and close the door nine times within 30s (LED will turn ON).
Once: Passive arming OFF.
Twice: Passive arming ON.
I have a PDF for the alarm somewhere that details that procedure.
Never got round to trying it tho! :lol:
