Aygo Blue Front Fog Lights
robin cutts
Just picked my new aygo blue, very pleased with it apart from the fact that the front fog lights do not come on when i turn on the fog light switch. The rear fog light works o.k There is no special switch ??Must not be connected. Any one else had this problem. Back to the dealer on monday
Front fog lights - seperate switch in the most stupid place RHS of steering column next to the Passenger Airbag on/off switch in that cubby hole.
Genius idea ! you're about to crash, don't like the passenger much, airbag OFF !
That's almost as good as an ejector seat ! :thumbsup:
No won't work bond style. :huh:
You have to use the igrition key, plus its a rotary switch and only works with the ignition off.
I did not think that the new Aygo Blue was fitted with front fog lights as standard :)
Probably like mine -style pack option, dealer fitted option including alloy wheels and scuff plates
Absolutely - that's how my Aygo Blue has them.... :thumbsup:
agreed stupid place to put the switch, I keep forgetting they are on and getting flashed at for being a chav, rear one turns off automatically, this one if I managed to catch glimpse of the little green led light on it I am lucky.
