Exhaust Manifold
Aamir_bt
sup,
i've been searching for some info on a few toyota cars that would be very helpful to me.
the main thing i want to know it if this manifold appears to be similar to any of the toyota manifolds here:
the important part is the bolt pattern of the manifold-to-head part, i really could careless about the downpipe flange.
i am working an a project and am trying to cross reference what parts will work since the car i am working on is kinda rare, and if i could find a toyota engine that has a manifold that would fit then it would probably be a whole lot cheaper and easier to find other options, like headers and turbo manifolds, etc.
so if you think there is a toyota manifold that would be even slightly similar to that one then post up what year and model car the engine was in or the engine code and i would appreciate it. :)
thanks for your help!!! B)
well here is a list of vehicles that appear to have a similar bolt pattern that i've found:
Year.........Make......Model...........................Engine
# 1995 TOYOTA TRUCK PICKUP.............L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1995 TOYOTA TRUCK PICKUP: DLX ....L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1995 TOYOTA TRUCK 4RUNNER: SR5...L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1994 TOYOTA TRUCK PICKUP.............L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1994 TOYOTA TRUCK PICKUP: DLX ....L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1994 TOYOTA TRUCK 4RUNNER: SR5...L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1993 TOYOTA TRUCK PICKUP.............L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1993 TOYOTA TRUCK PICKUP: DLX ....L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1993 TOYOTA TRUCK 4RUNNER: SR5...L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1992 TOYOTA TRUCK PICKUP.............L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1992 TOYOTA TRUCK PICKUP: DLX ....L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1992 TOYOTA TRUCK 4RUNNER: SR5...L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1991 TOYOTA TRUCK PICKUP ............L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1991 TOYOTA TRUCK PICKUP: DLX ....L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1991 TOYOTA TRUCK 4RUNNER: SR5...L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1990 TOYOTA TRUCK PICKUP.............L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1990 TOYOTA TRUCK PICKUP.............L4 - 2.4L (2366 CC): GAS: CARB: N: 22R
# 1990 TOYOTA TRUCK PICKUP: SR5.....L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1990 TOYOTA TRUCK PICKUP: DLX.....L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1990 TOYOTA TRUCK PICKUP: DLX.....L4 - 2.4L (2366 CC): GAS: CARB: N: 22R
# 1990 TOYOTA TRUCK 4RUNNER: SR5...L4 - 2.4L (2366 CC): GAS: FI: N: 22RE
# 1989 TOYOTA TRUCK PICKUP.............L4 - 2.4L (2366 CC): GAS: CARB: N: 22R
# 1989 TOYOTA TRUCK PICKUP: DLX.....L4 - 2.4L (2366 CC): GAS: CARB: N: 22R
# 1989 TOYOTA TRUCK 4RUNNER: SR5...L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1989 TOYOTA TRUCK 4RUNNER: DLX...L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1988 TOYOTA TRUCK PICKUP.............L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1988 TOYOTA TRUCK PICKUP ............L4 - 2.4L (2366 CC): GAS: CARB: N: 22R
# 1988 TOYOTA TRUCK PICKUP: SR5.....L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1988 TOYOTA TRUCK PICKUP: DLX.....L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1988 TOYOTA TRUCK PICKUP: DLX.....L4 - 2.4L (2366 CC): GAS: CARB: N: 22R
# 1988 TOYOTA TRUCK 4RUNNER: SR5...L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1988 TOYOTA TRUCK 4RUNNER: DLX...L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1987 TOYOTA TRUCK PICKUP.............L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1987 TOYOTA TRUCK PICKUP ............L4 - 2.4L (2366 CC): GAS: CARB: N: 22R
# 1987 TOYOTA TRUCK PICKUP: SR5.....L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1987 TOYOTA TRUCK PICKUP: DLX ....L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1987 TOYOTA TRUCK PICKUP: DLX.....L4 - 2.4L (2366 CC): GAS: CARB: N: 22R
# 1987 TOYOTA TRUCK 4RUNNER: SR5...L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1987 TOYOTA TRUCK 4RUNNER: DLX...L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1986 TOYOTA TRUCK PICKUP ............L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1986 TOYOTA TRUCK PICKUP.............L4 - 2.4L (2366 CC): GAS: CARB: N: 22R
# 1986 TOYOTA TRUCK PICKUP: SR5.....L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1986 TOYOTA TRUCK PICKUP: DLX.....L4 - 2.4L (2366 CC): GAS: CARB: N: 22R
# 1986 TOYOTA TRUCK 4RUNNER: SR5...L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1986 TOYOTA TRUCK 4RUNNER: DLX...L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1985 TOYOTA CELICA: ST...............L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1985 TOYOTA CELICA: GTS.............L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1985 TOYOTA CELICA: GT...............L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1985 TOYOTA TRUCK PICKUP.............L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1985 TOYOTA TRUCK PICKUP ............L4 - 2.4L (2366 CC): GAS: CARB: N: 22R
# 1985 TOYOTA TRUCK PICKUP: SR5.....L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1985 TOYOTA TRUCK PICKUP: DLX.....L4 - 2.4L (2366 CC): GAS: CARB: N: 22R
# 1985 TOYOTA TRUCK 4RUNNER...........L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
# 1985 TOYOTA TRUCK 4RUNNER: SR5...L4 - 2.4L (2366 CC): GAS: FI: N: 22REC
if anyone has one of those vehicles and happens to have a head or manifold laying around, then if you don't mind taking measurements of the bolt spacing then that would be super awesome.
thanks.
edit:
also, the manifold i pictured in the first post says it will fit 87-93 toyota's. it doesn't say what toyota though, just 87-93, so that's what led me to wonder if it really does cross fit with toyotas. to let you know the manifold is for the Isuzu 4XE1-V 1.6L SOHC engine, and finding aftermarket parts for that engine is hard, like manifolds. :rolleyes:
