Full Toyota Parts Catalogue
adilmon
Click the link for a full Toyota Parts catalogue
http://www.akadia.ru/_pages/toyota/
select EBPONA, then choose Celica from the tabs & enjoy :)
Please can you make this sticky?
Cheers for that. Very handy site to know about. I find parts pictures better than the ones in the workshop manual.
its no where as good as the cd rom , its not very model specific , where as the cd rom is.
good find though , lets you see basically whats what and what goes where.
What cd rom. Where do I get one of those.
this one here covers your gen 6 celica . its down at the bottom , download both cd's
http://www.yankeetoys.org/docs.htm
dvd version here --- http://thepiratebay.org/torrent/4015123/Toyota_EPC
Cheers. I'll have a go at downloading. Thanks.
Copied both cd's, got epc to work but can't get to load the cd's. Looks like I'll have to go without. Cheers for help. Might try dvd later.
CD BURNER NOTES:
1) Make sure you unzip the files before burning. I know it
sounds stupid but somebody will do it.
2) The files have been zip straight off the CD so make sure
your directory structure is right for the burn.
(IF YOU DON'T USE THE RIGHT VOLUME LABELS THE CDS WON'T WORK)
3) The EPC1.zip files should be burned to a CD with the label
"19950622E1"
4) The EPC2.zip files should be burned to a CD with the label
"19950322E2"
5) Setup and installation notes are in EPC1.zip in the
EPC\readme.txt file
HOW DO I MAKE THIS $#%^ THING RUN ?
As I stated in the previous message posted to the list. You have to put
the images onto CDs in order to run the program. Make sure the volume labels
on the CDs are 19950622E1 for EPC1.zip and 19950322E2 for EPC2.zip. If you
don't have the right volume labels on the CDs the program will install but,
won't run properly.
Once you have the CDs, run the "setup.exe" program in the "EPC" directory
on 19950622E1. Leave all of the options as default. If you have more than one
CD-ROM drive go ahead and set it up during installation.
Once the installation is finished, run "EPC for windows" from the start
menu. Select CD setup from the main menu. Select CD setup from the second
menu. Next check the European area version check box. Next click the add
button in the European area version box. You will be presented with a change
status dialog box. select CD-ROM from the radio buttons and highlight the "A1
CD-ROM" and "A2 CD-ROM" choices in the list box (use the shift key). Then
click the OK button. Next press F10. The program will prompt you for both CDs
during the setup phase. Once the setup is completed, press F3 to return to the
main menu.
CD BURNER NOTES:
"19950622E1"
"19950322E2"
EPC\readme.txt file
won't run properly.
main menu.
Cheers for reply. Yes I did all that. The epc programme loads ok but it won't load the info off the discs to run. i.e. when you get to "press f10" nothing happens. I guess it should load the discs but it don't.
