2004 2d Will Not Start When Hot But No Prob When Cold
daws
Hi Guys
Got a 2004 D4-D, just had a service and will not start when hot but no prob when cold. So I am snookered if I stall etc.
I have the car under warranty so should be OK but does anyone had this happen and know the cause?
cheers
daws
To daws.
Too many variants that can cause starting ( from st/motor to engine sensor? ) trouble. You say car has just been serviced & is under warranty, i would bring it back to garage.
Regards, Beagh.
Hi Guys
cheers
daws
hi mate
deliver your car in order to rectify it under warranty.
it looks like due to heating some el contacts got loosen.
have starter solenoid contacts inspected first.
cheers/Igor
Hi Guys
cheers
daws
hi mate
cheers/Igor
No probs with the starter motor as the engine tries to start but wont 'kick-in'
will be going to dealer but would like to know if anyone had this and had it diagnosed so that I don't get "computer says no!"
cheers
Hi Guys
cheers
daws
hi mate
cheers/Igor
cheers
ok the onlny problem with SCVs then or with their control circuit
cheers/Igor
Hi Guys
cheers
daws
hi mate
cheers/Igor
cheers
cheers/Igor
Cheers Igor m8 - is the SCV control circuit linked to the glow plug circuit as I am getting glow plug circuit A error as well?
If it is would make sense
cheers
Hi Guys
cheers
daws
hi mate
cheers/Igor
cheers
cheers/Igor
cheers
hi
you have to check both SCV and glow plugs circuits to exclude each link in this issue chain.
It is good practice. Good luck
Igor
Hi Guys
cheers
daws
hi mate
cheers/Igor
cheers
cheers/Igor
cheers
hi
Igor
cheers Igor
For info
took car to dealer, they replaced glow plugs, starter motor and reprogrammed ecu - all cushty!
cheers
