Help Toyota Supra Locking Wheel Nuts
lucyforyou
How to i find out the size of the alum key for my locking wheel nuts as i am having trouble getting new tyres. No tyre fitter has the correct tool. Can i change them and if so where in stevenage and what will it cost.
Toyota did a few different versions of their locking wheel nuts. Your best bet is to take your car to your nearest Toyota dealer and get them to match it up to a set.
Otherwise if they are aftermarket and you dont have the correct bit you'll need to get someone to remove them for you which can be tricky.
They can be drilled out if you have patience and a steady hand.
  • 2 months later...
