Ae86 4A-Gte Engine Rebuild
AE_92
Hi all as some of you will know I blow the engine on my ae86 Decided to rebuilt it with stronger parts and hope of some better reliability I know my major problem is the ecu as no one in the UK(and probably in the whole of Europe) can map this thing! so iam looking into getting a different Ecu (anyone recomend any decent ecu's?)
any way here are some pic's
here's the car looking sad :(
Now you see it
Now you dont magic! :D
also has a os Giken super single clutch which is nice the only thing bad about is its pretty worn out which is not nice as a rebuild kit cost 300+ quid :(
http://www.rhdjapan.com/os-giken-super-single-clutch-overhaul-kit-a-11947
also striped the block to see what had failed a lot of guys were saying that the ring lands have gone and I was thinking it was the piston rings which have failed but both the rings and the ring lands are f***ed :(
piston no.1 bottom compression ring has multiple cracks and the ringland fell apart in my hands
pistons 2 and 3 were ok
piston 4 had some cracks on the ring land
thats all for now will update when I get more stuff done :D
  • Replies 57
  • Created
  • Last Reply
Top Posters In This Topic
  • AE_92
    25
  • KPARRIS-JONES
    20
  • 4afte
    7
  • dawesy
    4
Holy crap that's some serious damage! :o
Glad you are sorting it out though. :yes:
I am going for a Haltech PS1000 fully reprogrammable ECU, there is the Haltech PS2000 but the 1000 is for up to 5 Cyl. engines and they are also suitable for Turbo and Charger applications. :D
PS1000
Look at my price list and it has the UK GBP price. Something like £945.... :o
The same people do many clutches so take a look around. :thumbsup:
PS1000
that haltech looks good nice price to like the sound of anti lag and Launch control lol :D
Nooooooooo lets hope you get it fixed quickly (as in, in time for JAE) :thumbsup:
dont worry it will be fixed...............it's actually already fixed lol these pic's were taken about two and a half mouths ago :thumbsup:
Good. Tell me what it's like before I go for one. :P :lol:
In one word It's LONG!! lots of late nights, lots of stress, lots of waiting for parts to arrive and lot of research
but it was great fun :thumbsup:
ha yeh it is exactly the same with mine. Can't wait for this weekend, should be taking a nice look at my crank and rods fairly soon. :D
stripping a engine down is great fun to :thumbsup:
then comes the long and boring task of cleaning eeeeeveryyy sssssinnnngle part :yawn: ............except the parts you are going to replace they come nice and clean and shiny :lol::thumbsup:
Yeh so true! The only standard parts will be the block, head, TVIS, oil pump and gearbox! :lol:
Btw, do you know what paint was used on the block? It doesn't look like high temp paint to me... :huh:
not sure when I sprayed mine I just sprayed normal paint on it seems to be fine
Ok here comes the fun part, all my nice and new and shiny parts :yahoo: ..................but took over 2 months to get them all!! :ffs:
in the pic's:
Arias 82mm forged low compression pistons (8.6:1)
Spool H-beam Con rods
ARP rod bolts
ARP Head studs
ARP Main studs
ARP Flywheel bolts
ACL Main bearings
ACL Con rod bearings
ACL Thrust washers
Driftworks Magnetic sump plug
INNOVATE XD-16 16 in 1 WIDEBAND GAUGE KIT
HKS Fine tune Timing belt
Zakleecorp clear cam cover
Toyota Oil pump
Toyota Water pump
Toyota engine gasket kit
Cheap oil filter
Continental drive belt
Cam cover washer seals (did not come with the Toyota engine gasket kit!!)
Camshaft oil seals (did come with the Toyota engine gasket kit but I lost one and broke the other oops :rolleyes: )
Not in the pic's:
HKS Cam gears
HKS 1.6mm Metal Head gasket
Kelsport 4age sump pan bolt kit
OS giken clutch rebuild kit A
Denso IK22 Spark plugs
Cheap engine oil
Mocal 19row oil cooler
Ported and polished head done by me :D
Engine Machine work done:
Rebore Block
new core plugs
block skimed
head skimed
crankshaft balanced and polished
Parts purchased before
Garret gt2860r
cheap eBay intercooler
autobahn88 de-cat pipe
more pic's to follow :thumbsup:
How the hell did you afford all this within a week!!?!? I have to wait years to save the cash I need! :o
NICE! :thumbsup:
oooo, lots of new shiney parts, very tasty. shame about the ringlands on your old one, make good paperweights though. got an ECU yet?
NICE! :thumbsup:
saving all my pennies :thumbsup:
no not yet :( getting steve at FCtuing http://fctuning.com/fctwp/ to have a look at the freedom see if he can map it hopefully he can would save me a lot of cash if not I'am going to go for Either the Link g4 or Haltech PS1000
have you looked at the Link G4 range of ECU's?
excellent value for money clicky
id advise against anti lag. its great for showing off but turbos dont last long when using it :(
yeah was looking into the Link storm G4 and Thor are doing a very good price I think it about 1500 supplied,fitted and mapped!! which is a very good deal IMO
as for the anti lag I think I'll give that a miss already been through 2 turbo's lol
ok back to the build before I continue I thought I would show some vid's that helped me alot on this build
Sr20det rebuild I know it not a 4age but it still uses the same principles of high performance engine building
http://www.56.com/u34/v_NDk4MTkwMjM.html
and this is a vid on the 4age it's in Japanese but you still get the idea
and I also used a 4a-ge service manual but I can't find the web site I got it from (anyone know how to host files?)
here's my work bench the boot lid of my skyline lol :lol:
the block cleaned,sanded down,sprayed then cleaned again ready for bearing and crankshaft installation
crankshaft installed and torqued down
looking good, love the workbench, where can i get one? you sticking with stock black for the cylinder block then?
lol, yeah just sprayed it black as it was the only colour I had, no money to buy some different colour I'am on a tight budget (But I did want to spray it purple lol )
Awesome work, I should be posting pictures of the same thing in a weeks time! :yahoo:
sweet :D
Now the next part is to measure each piston ring and file it (if needed) to spec's now this is a long because you have to put the ring square in the bore then measure it if it to small(which they all are, none of them are the right size out of the box) then you take it out and then file a little then place it back in the bore measure and repeat until it the right size and you have to do this for every single ring!! :yawn: lets just say I started at 11am and finished at 5am in the morning!! :yawn: (Watch the SR20 rebuild vid I posted to see how it is done)
Mounting the arias pistons and the spool conrods looking sexy :thumbsup:
putting the !Removed! rings in lol :lol:(I never want to see another piston ring in my life!! :lol: )
pistons mounted and torqued to spec
Again, super cool! :yes:
Have my engine now, going to begin the strip down tomorrow. :D
Great work mate, some serious parts and hard work going into that engine, good luck and keep the pics and updates coming!!
thanks mate, bet you can't wait :D
thank and heres another update for ya! :D
ok so more pic's, I sprayed the sump in high temp matt black which I think looks pretty badass B)
oil pump,sump,driftworks sump plug and the kelsport bolts installed and torqued down to spec :D
closer pic of the matt colour and the bolts
I liked the colour of the sump so much that I had to spray the cam covers the same!
next the arp head studs installed
pic's of the ported and polished head done by me which I think came out Ok could have spent more time on it but it all good :D
valves in
shim and buckets cleaned and ready for installation
HKS metal head gasket installed
Head installed and torqued to spec
camshafts installed
a quick pic to see how the covers look like on the engine (I know there in the wrong way but hay it was 5 in the morning and I was tried :yawn::lol: )
