Ivan's Ae101 Build Thread 4Age Bt 20V6Spd No 56K
JDM20VAE101
Gas Tank Coating 2-27-14
As It come...
Start applying the Coating...
Coated with rust inhibitor paint and Ready...
Lines and seals Installed...
Gas Tank Exhaust HeatShield Installed 2-28-14
Installing the new Gas/Fuel Tank...
Gas/Fuel tank Installed and Exhaust Heat Shield Back in place...
SS Braided Brake Lines 3-9-14
Stainless Steel Front Brake Lines
Installed
Banjo Fuel Fitting 3-18-14
Banjo -6AN Fuel Fitting In Place for the Custom Tucked Fuel Lines.
Red Horse AN Fittings 3-20-14
Fittings for the Custom Tucked Fuel Lines...
E85 Stainles Steel Nylon Braided Line 3-25-16
E85 Stainles Steel Nylon Braided Line for the Custom Tucked Fuel Lines
Making Custom Fuel Lines 3-28-14
In the making of the Custom Fuel Lines... Hose and Fitting Attached Both Sides...
AN Flaring Fuel Pump Base 3-28-14
Cutting the Oem line with Flare and nut.
Cleaning the line before flaring.
Installing the -6an Sleeve, Sleeve nut on the Line from the Fuel Pump Base Assembly and flaring the line...
Done!
Radiator Mod Lower Outlet 3-28-14
Modifying the Lower outlet of the radiator to get some clearance with the engine mount bolt.
Welding...
Modified and ready for test fit on the cra...
Perfect!
NEW OEM Clutch Brake Rubber 4-3-14
NEW OEM Clutch Brake Pad
Custom Fuel Line 4-13-14
Custom Fuel Line Done!
Fuel Lines Cover 4-17-14
Donor Car...
Will be using one OEM Feed Fuel line as for return and the Cover for it.
Cleaned and Ready...
Intalled on place using all OEM hardware.
Custom Feed Line and Return Line in Place...
Done ready for the Fuel Pump Assembly...
On ‎13‎/‎10‎/‎2016 at 2:39 AM, JDM20VAE101 said:
Hiya Ivan, your car will be better than a new one by the time you have finished if you haven't now that is? Mike.
Hi Mike! I hope you are doing well my friend! Yeahhh!!! Almost there, Just correcting some electrical issue with the engine. But Now I recover my old laptop hard drive, so I can upload the pics of the chronological progress on the build.
Fuel Line Tucked Routing 4-23-14
Tucked Fuel Line Routing...
In Line HR Fuel Filter 4-24-14
Hybrid Racing In Line Fuel Filter...
Yeahhh I'm ready!
Intallation...
In place...
Intalled...
AE111 Vs AE100 Fuel Pump 4-26-14
AE111 Vs AE100 Complete Fuel Pump Assembly...
Ready to Install...
My kid 5-3-14
My Kid on the Car...
Fender Brace 5-5-14
New Portable Tool Box
Fender Brace In Place...
Need to make a hole to install the nut that will hold the bolt of the brace.
My Friend Michael Helping with it...
Installed...
Installing Custom Tucked Fuel Lines 7-7-14
The Fuel line was hidden routing installed...
Now the return line won't fit as I want it to the new routing... I have clearance issues with the Air Box plate...
Install the back plate bending a bit the Return line.
With a lil Bent goes right there...
Thats how it looks in the new position...
And here a example of the routing, just need to hide and attach it behind the Feed Line...
Engine Bay 7-11-14
Engine Bay Pics...
Air Box Fitted Fuel Lines 7-15-14
Installing the OEM Air Box
Installed and Fitted the Tucked Fuel Lines
Another view, how hidden are the Fuel Lines. Now I'm Happy with that routing...
Officially the Tucked Fuel Lines Complete!
Tom's Gauge Beezel 7-16-14
Brand New In Box Authentic Tom's Gauge Beezel
Hi Ivan, is this part a cover for the dash board and goes around all the gauges? Mike.
Dinng Diinnng Dinnggg!!!!
Yes my friend! you are correct!
