What's This Valve Called? And Where Is It Located In The Engine Ba
SmithCraig896
What's this valve called? And where is it located in the engine bay of 2003 avensis d-4d?
and what does it do?
dont have much knowledge sir but is this not the SCV (suction control valve) common problems are similar to clogged EGR Valve
e.g cutting out at junctions etc
not sure where yours might be but in the 2007 1adftv engine it is on the fuel pump on the right side of the cylinder head..
changed mine recently and cured cutting out problem.. hope this helps you sir but my knowledge is sketchy
