Suspension lubrication ?
oldcodger
Will be renewing the wishbones complete with rubbers and wondered if the rubbers should be lubricated with anything or just left dry so they don't attract and dirt ?
Also the bush bolts, best to give then a careful grease  or again left dry ?
Was going to give the metal work a coat of Hammerite  unless there's anything better ?
Silicone Spray may be better, but their is Silicone or Red Rubber Grease.
In general, I like to grease suspension bolts, though not yet had to do anything on my Corolla (assuming that the rubber bushes have a steel inner sleeve). If nyloc nuts, then I'd try and avoid grease on the thread the nyloc engages on.
Where, in the past, I've had to fit/squeeze rubber bushes into the wishbones, I've tried using Waxoyl, though I can't remember how successful it was.
Thanks guys,
The wishbones I have ordered come with new rubbers bushes  and new ball joints already fitted.
Polyurethane bushes last longer. Worth consideration but are more expensive if you can find them. Silicon spray is best to put them in with.
