X-Touch Software Update?
Ian J R
Hi All,
could you please share with me the instruction about how to update my unit from present version: 8.10; 8.10; 8.14?
Your help will be much appreciated.
Kind Regards,
Peter
Dear Flash,
Would you be so kind to pm me the link for the latest update firmware?
My system:
Model : 18PPDAEU-EA00
Part nr.: 86140-YV010
Audio : 810
Syst.1 : 810
Syst.2 : 8.14
It might fix some problems i'm having.
Thanks.
On 11/27/2022 at 11:27 AM, Richie_NL said:
My wife is having some troubles with Apple Carplay and taking/making calls, so I was wondering if an update would help, but I'm not exactly sure.
I did manage to find an update but as I presume, I may have to do an older update first, if I don't want to brick the unit?
Hi Richie,
I'm curious: when you press "Details" on this screen, what is the version of your software in the description?
Can you check it?
Thanks, Peter
On 9/10/2023 at 1:20 PM, Piotr77 said:
Hi All,
Kind Regards,
Peter
What model do you have ? 86140-YV020 ?
Hi , I've been trying to update my radio with 18PPDAEU-EA01_0860_D.avh but when installed on a USB device does not highlight to update software any ideas ? Does the USB have to be a certain size or format ? Currently on 0840 Op 0621 . Citroen C1 Hard 86140-0H020 Model 13TPDAEU-EA01 Thanks in advance
Formatted fat32 or exfat and no bigger than 64gb
Yes, exactly this model: 86140-YV020
Because you have the wrong update for your system
Hi everyone,
Scrolled through the internet and it looks that most knowledge is here 🙂
I recently bought a Toyota Aygo, manufacturing year 2019 and assumed that Apple Car Play would be available on this model but apparently it is not. Is there any way to have that installed through a software update as I have the impression that it should be possible on this type of radio. See details below..
Any help is appreciated.
That is the Aygo triple play (3 button without DAB) yes it's the AA/AC radio
AA/AC is over USB on these units
First off, does the USB port work ?  Try it with a USB stick with some MP3's on it
User manual - https://www.toyota-tech.eu/aimuploads/2f9eecda-0ac2-4542-aa77-b5fc8c7cc4cb/Aygo_Pioneer Multimedia System_en.pdf
Just tried a USB stick and indeed it plays the MP3's.
ok that shows the USB port is working, set it up as per the manual above and make sure you have the app installed on the phone
Make sure you have a decent cable (Apple ones are built cheaply but cost a fortune)
Hi flash 22.
Would it be possible for you to send me the latest software for my Aygo 3 button head unit please?
Model - 86140-YV020
Audio - 8.10
OS 1 - 8.10
OS 2 - 8.14
Best regards
Mike
Just an update to my previous post.
I flashed the new firmware this  morning & my head unit now works fine with Android Auto on my Pixel 7 phone.
The issue I was having was the person I was phoning couldn't hear me when hooked up using Android Auto. Using bluetooth it was fine.
Once again thanks goes to flash22
Regards
Mike
Hi!
I have similar problem like Mikey66. @flash22 could you send me update to the newest availiable vesion?
I have 86140-YV010 hardware and 18PPDAEU-EA00 model.
Dawid
I bought a used Aygo and i need to update my nav too. Can you sent me the link /file also pls.
Thnaks
On 10/27/2023 at 7:32 PM, Mikey66 said:
Hi flash 22.
Model - 86140-YV020
Audio - 8.10
OS 1 - 8.10
OS 2 - 8.14
Best regards
Mike
Hi Flash 22,
Could you send it to me too pleasE? got the same version as this screenshot
8.10 on a 2020 is odd, it should have been 8.12 or 8.14 from factory
pm on its way
