X-Touch Software Update?
Ian J R
Hello @flash22
Could you send me the update for this radio ? I have the problem that I can't hear caller speaking when Android Auto is running.
Are the updates multilingual ? My radio is in French.
Thanks for your help.
Updates are euro-wide, default is English, not seen an update yet that has changed what was previously set
  • 4 weeks later...
Hi all!!
Could you send me the latest firmware available?
Thanks!
Hi Flash22,
I'm a new a guy here. Since a while I'm looking for an update for my audio and I m happy now that I've found this place. I have scrolled through this topic and saw that you @flash22 are the man of solution here. 😀 Would you be so kind to send me the 850 update? For reference I have the system status as on the pic.
Thank you very much!
Hi im new AYGO 2 owner, im looking for the update for audio. can you help @flash22 ?
Hi Flash 22
Would you be so kind to send me the firmware update for head unit 86140-YV020
Currently Audio 8.10
Os 1 8.10
Os 2 8.14
Thank you so much in advance
Steve
Hi, new here. Currently have the 3 button model (86140-YV020)
My Android Auto is constantly crashing every 20 seconds. Tried a bunch of different usb cables and also got my Android Auto app on my phone up to date.
Would anybody know what's causing the crash???
I've attached a pic of the current software running on my head unit.
that firmware is current (looks like the unit is from a 108) try disabling your bluetooth and make sure your phone is fully charged
Hi @flash22 thanks for that, seems to have helped.
Although I've noticed any movement of the cable around the USB port does cause it to crash.
Doing some searching online, I've read that non official cables can cause issues. So I've ordered an official USB cable for my Samsung
If that doesn't help, may have to consider replacing the USB port. Has anybody done this before?
Hi Flash 22
Would you be so kind to send me the firmware update for this head unit
Doing some searching online, I've read that non official cables can cause issues. So I've ordered an official USB cable for my Samsung.
Update: got the official USB cable today and all working fine.
I am looking for the newest software version for my aygo. In order to connect iPhone 11
I would be grateful if somebody could please forward me the relevant software updates for my unit.
Good day flash22, can you please send me the update for this?
Thank you very much
On 10/18/2021 at 4:54 PM, flash22 said:
Map updates are by SD card, only updates i have is for the later tripleplay 86140-YV020 but i can have a look
I have the 840 firmware if required
Hello Flash 22, you are my last hope to fix this. I want to try and update my Toyota Aygo 2015 screen, but I did not find the update files anywhere on the internet. Could you please be so kind and send it for me? Thank you in advance
Hi Lads,
Does anyone have any soft for Aygo available yet?
I have currently for 13TPDAEU-EA01 / 86140-0H010 installed Audio 830 / OS: 621
And never got the mirror link AppInCar working with any iPhone (tried on SE2020, 11, 14, 15)
850 or even 840 will be much appreciated!
Mirrorlink is as useful as an iPhone 1st gen, its long since dead and very few phones support it
updates do not add any functionality to the radio 830 will have the most up to date for mirror link
pm on it way
hey flash22 can you maybe send the 850 update to me i current running 810
thanks 😄
Hi @flash22
Can you please send me the newest software for this radio?
86140-YV020
Currently I’m at 8.11, 8.10 and 8.17
Hi @flash22
Hello flash22,
May I ask you to send me an update too? I have the same problem as described above with AA.
Many thanks
8.12 is current, make sure your phone is up to date and you have the newest AA app, disable BT when using AA
Hi, I recently purchased a 96140-YV020 unit for my Toyota Aygo which has the software installed as per the photo. I can't get Car Apple Play to work! What do I have to do? Someone can help me?
make sure the USB is working with a USB stick with some mp3's on it, did you have the Xnav (factory nav) before
What are the advantages of updating the 2 button older model? Mine has never been updated (64 plate).
