X-Touch Software Update?
Ian J R
if it works leave it alone
@flash22 i have the same problem as described many times here... When i get a incoming call it will go to my phone speaker instead of the car audio. Can you sent me the update?
My current version is:
Audio: 8.10
Operating system 1: 8.10
Operating system 2: 8.14
Thanks!
What model do you have
YV010 - without DAB
YV020 - with DAB
I have the YV020 with dab
Hi all,
The following error occurs while plugging my phone with USB to the system: "USB-Device is not compatible". I can't use Android Auto this way.  I have not tested an iPhone yet.
Does someone know what to do?
Hmm so far I have tried it with multiple cables but it still doesn't work. The app is up to date. My phone is old though, it's a oneplus 6t. Anymore tips?
you need to set the connection type on your phone if not try going into developer mode and turn on USB debugging
So I managed to find the solution to my problem. The previous owner installed this 3 button headunit, however he didn't do it well. So I took the radio out and plugged it like it is stated below in the picture. Now it is working well!
Thanks for the tips though.
8.12 is current, 8.14 only comes on factory units
That will do it, the x-nax is not compatible with the triple play
@flash22 it seems you are the person to ask.
Would you do me a solid and send an update my way?
Thanks in advance!
@flash22 Can you send me the last update for:
Model-ID: 18PPDAEU-EA00
Hardwarenr.: 86140-YV010
I have actually the 8.10.
 Thank you very much  in advance.
@flash22Can you send me the last update for the system indicated below, please?
@flash22 Could you possibly send me the update link?  Version as per below:-
Thank you very much 🙂
Hey! I have a Citroën C1 from 2016 and haven't had an update since then. Where can I find the current software and future updates? @flash22 I see many asking you. Could you provide me this?
Model ID: 18PPDAEU-EA00
Hard No.: 86140-YV010
Audio: 8.10
OS1: 8.14
OS2: 8.14
Thank you very much!
Please could someone send me the update for my system please?
Model ID: 13TPDAEU-EA01
Audio: 810
Operating system: 0621
Audio: 8.10
OS1: 8.14
OS2: 8.14
Hi @flash22! Could you take a look for this one too, please?
I must of overlooked it, sorry
HI,
I have a Citroën C1 from 2016 too and haven't had an update since then too.
@flash22 I hope you will help me with my request for the update if it is possible. I am not firm in what works with what SW so ..... please have look at the pictures.
Many thank' s !!!!
Hello,
Are you able to help me with the firmware for this 3-button system please?
Hi! i have an aygo 2015. My id software are: 13TPDAEU-EA01. I read that I have to do a 2-step update. But I couldn't find the files to put on the flash drive to update the radio system. Could someone send me the files to use? Thank you
what software version do you have? anything above 810 is a one-step update - 850/0850 is the last update
updates do not add any features
hi, i have S.O. 0621
