Help and advice please toyota yaris cross airbags deployed but braking power low displays
Abid ABS
Update i coded the srs module airbag light has cleared how ever only issue the abs is still in fail safe mode same code brake power low abs malfunction secondary brake malfunction parking brake malfunction
C052f14
Check the ABS 1 and 2 fuses are good, and you have power, but it may be a case of it not being able to carry any current
Apart from that, replace the ABS ECU or find someone to fix it, the fail-safe is internal to the ABS ecu
you could give Autotronics a call 0116 276 7054 and see if they can help
Disconnect the negative on the 12v Battery, leave it for 5 mins and then check the resistance between pin 1 on the ABS plug and the body
Edit. Do the brake lights work ??
1 hour ago, flash22 said:
Disconnect the negative on the 12v battery, leave it for 5 mins and then check the resistance between pin 1 on the ABS plug and the body
Yes break lights work parking break works when doing activation test with diagnostic it can be heard 1 but there is another active test that fails and blinks the hazards lights
Just replaced the abs module and still got the code regarding short to ground ect along with a bunch of other codes as its not coded didn't see the point in coding as I just plugged it in to see if the error would clear .. so now im totally stuck ..I did test pin 1 and got a reading then went to 1 on the meter
Apart from front bumper that needed replacing there was no wiring damage even the radar was intact ..
I noticed the inside fuse box cover was missing with 3 fuses missing any one got a photo of the cover to see the fuse location  it's under the glove box please
You need to code the module to the car, then clear the codes otherwise it will drop into fail-safe, have you look to see if there is a cal file available
TS - have you tried to run the active tests on the ABS ? Chassis / Brake / Active Test / Motor Relay
I take it you have done a steering angle zero point calibration
Yes I did reset memory and tried calibration does the same as the other one  did .I didn't bother to code it in as the fault code short to ground should not have been there I'm starting to think its something else
Abs has 3 powers ABS 1, 2 and (these are direct 12v an IGR - IGR is the ecu turn on, replace the ABS 1 and 2 fuse they may test fine but may not be able to pull current across them
Also check the fusible links and fuses on the positive Battery terminal (pop the cover off)
be aware this information is for the Yaris GR
https://www.toyaris4.com/toyota_yaris_system_diagram-543.html
Calibration is that using TS or the Autel ?
Also check the fusible links and fuses on the positive battery terminal (pop the cover off)
Will double check again I've got both techstream and autel both in subscription
 That's a helpful link all fuses checked and continuity confirmed plus active test all work even live data shows power feeds wheel speed sensor values ect .but yaw rate and steering not configured.  Due to unable to calibrate .. I noticed a few fuses missing inside under glove box combination meter as fuse box cover was missing when I got the car..and I have read that secondary collision brake  is applied when airbags are deployed to stop the car from rolling  but my question is how to get it out this mode after replacing airbags and ecu .just to confirm i coded it
3 hours ago, flash22 said:
Yaw may be an issue
have you programmed the SRS module for that car with the Cal file - this has to be done while online
you can download CAL here if you haven't already
https://www.toyota-tech.eu/DiagnosticTools/ecu.aspx
Yes when connected online it said necessary and need to be unlocked ecu security key and done that online all airbag fault gone and when doing a full health check it dont show any faults other than in the break epb  c052f14
Looking at C052f14 a bit closer and why they say to replace the whole module, is not the ABS ecu, but it's more than likely it has burnt the motor out
can you see any part numbers on the ABS pump body (metal part)
But with the replacement still had that code that's why I'm so confused
Is that a complete abs pump ?? Or just the ecu, have you tried a CAL update on the ABS
Was a complete assembly pump and module... cal update in techstream in utility reset memory and calibration.  I don't see calibration update ?
I've got the headlights disconnected and daytime running lights disconnected if that causes anything
Yaw rate sensor undone . My problem is I can't get it to recalibrate.  What I do is
Reset memory then calibration then it says abs and traction light will blink for 2 mins mine does not and says if it dont to re try with parking break released.  But tried and not getting anywhere
