Steering wheel clock squib
mds33
Toyota IQ2 horn not working. I’m told I need to replace the steering wheel clock squib.
has anyone had similar issue?
Where can I source clock squib as local supplier has quote £700+ +vat
What's a clock squib and what does it do?
It's a device to allow electrical connections to turn with the steering wheel. A typical clock spring may contain a long, coiled, flat flexible cable, shaped like the mainspring of a clock
Removed
Edited by mds33
Repeat info
From Wiki ...The coiled up 'spring' is contained in a plastic housing. When it fails, most likely all the electrical functions carried on the steering wheel will stop operating- That is the check a mechanic would use to identify the clock spring failure. In other words if the horn fails to work there could be many possible causes to investigate; but if at the same time the cruise control or other steering wheel mounted items do not work one can expect to find the clock spring is at fault.
Have you check the horn has voltage,its behind the front bumper on the right hand side.,the horn in the left hand side of the engine compartement is for the alarm buzzer only.If its the clock its an easy change,sterring wheel off,1 hours work
All wiring fuse and relay have been checked
All wiring, the fuse, relay and the horn itself has been checked and OK.m by a very competent mechanic.
He and I am amazed to be quoted £700+ +vat to supply 😱
  • Sad 1
Thats crazy money,I changed the left hand stalk a few years back,the steering wheel and squib had to come off,,,back on ,it took 1 hour from start to finish,somebodys making a big profit!!!
it sounds like they have quoted you for an airbag
I would go over the wiring, fuse, and relay again
you can do a simple test by shorting the horn pin to ground on the plug under the steering wheel
(Pin 8 ) whats usually black
if the horn sounds it's the spiral cable if it does not it is likely the integration relay (826411-74010) or the horn itself
you can have the best mechanic, but they may not understand or have access to enough data to be aware of the nuances of a particular car - this is where the owner's forums come in
  • Thanks 2
