New Member
button
THE WIFES G6 CORROLLA HAD THE ABS LIGHT COME ON,SENT TO TOYOTA REQUIRED NEW OSR ABS SENSOR.
HAD NEW GENUINE TOYOTA ABS SENSOR FITTED (NOT BY TOYOTA GARAGE) LIGHT NOW ON /OFF INTERMITTENTLY.
SPOKE TO TOYOTA SAID ECU/FAULT CODE REQUIRES RE SETTING.
DOES ANYONE KNOW IF YOU CAN DO IT YOURSELF OR IS IT JUST TOYOTA
THANKS FOR HELP
THANKS FOR HELP
Try disconnecting tyhe Battery for thirty seconds, usually wipes the fault memory, hope this helps :-)
