Avensis 2.0 D4d
grahame917
Hi,I am having problems starting my avensis,the problem only occurs however when the engine is HOT,I can turn the engine off and if i try to restart it immediately it is fine,however if for example i leave it for 5 mins or so to fuel up it always gives me trouble restarting.
can any one help?
can any one help?
hi
check with both SCV ell contacts at hot condition -- it might be losen.
Cheers/Igor
1cd-ftv engine fitted?? its the starter motor.
Hi thanks for the advice,How do i find out what type of d4d engine i have?It is a 2004 model ,115bhp
if the engine is belt driven then its the 1cd-ftv
will have a black plastic cambelt cover
later engines are chain driven
Hi there as above Starter motor is your problem .Dont waste your money and time paying idiots to scratch there heads im no mechanic and scrolled this site for days trying to find my problem.I eventually had a gamble at a starter motor and NOBODY would believe me when i said change it for me when i described the symptoms.
I ordered a brand new delivered for £100 approx and payed a mechanic £20 to come and help me change it.What i got was a starter that sounded instantly different ,it flew the engine over like nothing youve heard.The car fired up and started from hot ever since.
Lets face it whats £120 when we start booking cars in into Mr T .
If it isnt that then at least you have new starter to eliminate at not too much money.
