Where Can I Get Gearbox Diagrams For 2007 Avensis
darbyogill
wanted to adjust clutch on t3x but dont no were to adjust
Already gave you a diagram of the gearbox when you asked where to check the oil level in your previous post.
The clutch is hydraulic and has no adjustment as such but the pedal height can be adjusted at the rod which connects to the master cylinder, you will find this under the dashboard where the clutch pedal pivots.
You might want to check the hydraulic oil level in the brake / clutch reservior. If any has been lost it could suggest a leak at the slave cylinder, etc. Air getting in could affect the operation of both clutch & brakes.
Get someone to operate the clutch pedal for you. You can then observe that the clutch lever arm is moved by the slave cylinder at the bell housing to confirm its operation. You may need to remove some upper trim to see it on some variants.
On the 1.8 petrol engine the slave cylinder is at the front of the bell housing.
