Ivan's Ae101 Build Thread 4Age Bt 20V6Spd No 56K
JDM20VAE101
Going to TitoAutoPaint 10-23-13
Picked At Home...
Arrived To TitoAutoPaint & Inspecting With His Kid...
Sanding and De-Ruster 10-24-13
Sanding all the Engine bay to the metal...
Spending Time on facebook until the de-ruster work on the metal...
Wow, your little mechanic has done loads of work... :clap:
hahaha yeah!
Brake Braket Modified Test Fit 10-25-13
Modified Bracket
Test Fit to get the new Big Rotor Centered
Perfect Fit!
More Sanding and De-Ruster 10-25-13
Working the other side of the Engine Bay
More De-Ruster Treatment In Action 10-26-13
TitoAutoPaint Taking a Break 10-29-13
More Engine Bay Work 10-30-13
Wheels All Coats of Powder Out 10-31-13
Since I wasn't happy with the powder coating texture color and coats...
All Coats Removed... Wheels Sand Blasted...
Power Steering Delete 10-31-13
Self Etching Primer For Nude Metal 11-3-13
Sealing and Welding Holes 11-5-13
Sealing and Welding The Engine Bay Holes...
More Sealing and Welding 11-6-13
Hi Dude
Dunno who you are but i like seeing your posts and i admire the passion you have rebuilding your car...............incidently why are you welding up some holes?
Mike169
Hi Dude
Mike169
Thanks Man! I appreciate your comment! I'm doing a Shaved & Tucked Engine Bay...
Keep looking for updates!
Radiator Test Fit For Relocation 11-7-13
Make Sure To Mark before welding the bases
Radiator Modification 11-8-13
I didn't want to use the OEM Toyota Big Radiator Holders on top, I'm modifying the radiator to use ones like Honda/Acura for cleaner look on the engine bay...
You are a true craftsman Ivan and what i would describe as a 'fabricator'.
Your posts are very good and nice to see you progressing your project.
Regards Mike169 :bangin::clap:
Thank you very much! I appreciate man! keep looking for updates!
Radiator Bracket Welded 11-8-13
More Work... (Shaved Bay)
I'm with you my friend Raistlin and it's great to see Ivan's commitment and progress, incidentally Ivan can we ask which country you are in?
Regards Mike169
Thank you! I'm G;ad that you are enjoying my project! keep looking for updates!
Regards Mike169
Thank you very much man! Sure, I'm From Puerto Rico. :driving:
