Aygo (2015) infotainment upgrade Android Auto and Apple Carplay
remon1496
50 minutes ago, flash22 said:
It's plug-and-play, only base models without Bluetooth will require the factory Mic
please read the first page of this thread
I've read all the threads I could find, the touchscreen has some ports which the radio do not have, that's my question! I even checked YV010 vs 20 in case the DAB was the difference
YV010 is without DAB
YV020 is with DAB
the extra 8-pin connector is for the reverse camera, if you want dab you will need a DAB Aerial
information is in this thread
YV020 is with DAB
Yeah the DAB thing I understood. That's what I wanted to know, what the extra 8-pin connector was, if it was in this thread, I must have missed it. Thanks flash!
posted the info in a few threads, but here is a cut and paste...................
the 8 pin is for the camera
you can get retention adapters
Warning !!, Do NOT wire 12v to the camera plug as the camera is 6V
This is the socket view or wire side of the plug
Pin 1 - 6v to camera in reverse
Pin 2 - Video signal +
Pin 5 - Negative
Pin 6 - Video signal -
