Unidentified plugs
robsy
While checking on the water leak in my boot I found these disconnected plugs under the drivers side light cluster, anyone have any idea what they are for.?
Nope there not tow bar electrics i just looked them up
does everything work as it should ?
Bob you could try asking this guy from the aygo forum i think he works for toyota
he is a knowledgable person to ask
https://www.toyotaownersclub.com/profile/45863-devon-aygo/
I was just helping the op, Devon has enough to do - its only a case of tracking down the plug in a diagram and maybe cross-referencing connectors
Edit. Its a lighting connector (90980–12517) possibly a aftermarket towbar kit, trace the loom and see where it goes
sorry bob
i got you mixed up with the OP
devon would probably know off the top of his head without looking
what the plugs are for
Thanks lads, it does have parking sensors but the box is on the other side.
Edited by robsy
  • 9 months later...
I am posting this question here as i do have a similar question.
i just found those 2 plugs on the right side in the boot and i was wondering if the plugs can be used to attach rear parking sensor or a reverse camera.20201021_164322.thumb.jpg.87ed371dffd36127d328ca4b76559b57.jpg
On this note: Can anyone recommend some aftermarket parking sensor.
Another alternative I was thinking at is one of these: https://www.aliexpress.com/item/32988901583.html?spm=a2g0o.productlist.0.0.9b282417p4ysOq&algo_pvid=a1f9d1f1-3413-4479-8d98-446f3c817d74&algo_expid=a1f9d1f1-3413-4479-8d98-446f3c817d74-5&btsid=2100bdf116036190969271822e0f8f&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
but i don't know if it going to work on my car: Auris 2008 TR.
Thank you.
