Retrofit Cruise Control - Yaris
Tom Bu
Not worth the bother.  Wait until you get another car, and make sure you get one with it factory fitted.
1 hour ago, ALT_Apollo said:
Is it possible for a 1.0 litre to be programmed for cruise control? Because i really want it!
That would be a NO, No 1KRfE ecu was ever programmed for cruise control, the Mk2 Yaris never had cruise whatsoever
How about a 2005 YARIS 5DR Hatch YRX Model: NCP91R-AHPRKQ Engine: 1NZ-FE
Is this capable of Cruise Control retro fit?
No, CC wasn't available on the Yaris until 2012 (Mk3) - audio controls were a luxury on the Mk1
Hi, just purchased a 2013 Auris Hybrid. I fitted same stalk to my Lexus CT with no issue, but am aware of possible compatability issues with the Auris.
Is it possible to check somehow before I buy a stalk?
Model is 2013 (post facelift) Auris Icon Hybrid.
Thx 😁
It should be plug and play on the hybrid
stalk - 84632-0F010 (has speed limiter on the end of the stalk)
dont forget the cover and screws
had the exact same question (event the same year) via pm from another member
The CT is basically and Auris in a designer suit with more toys, parts are shared widely across Toyota, Lexus and even some Subaru's
Flash22, thank you so much for such a swift and clear response.
It's really appreciated. 😃
Sorry, the stalk appears to come with two thin patch leads a Red and a Black one with spade connectors on the end.
Are these required, or not used
It should be 1 cable one ends plugs into the stalk and a 4 pin plugs into the clock spring
the 2 extra wires with some Chinese kits are supplied, so you can wire it into the car if required from under the steering column in to the main loom if it doesn't have the factory wiring
  • 3 months later...
Hi!
Possible to fit cruise control on a 2015 yaris that is written as NSP130L-CHFNKW?
  • 6 months later...
On 5/4/2020 at 4:33 PM, Tom Bu said:
Hi I have a 2013 1.4d yaris NLP130R model number manual transmission.
Will just the stalk and wiring give me cruise or will I need a clutch switch?
Check the wiring under the steering cowl
Pin 1 and 2 is for CC
if not, PM me your VIN and I will look it up
My vin is VNKKC3D380A058915
Built - 09/2013
Model - NLP130R-CHFNXW
have a look at the wiring at that plug if you have wires at pin 1 and 2 it is wired for CC
if so, just add the stalk 84632-34011
On 9/9/2023 at 3:01 PM, flash22 said:
I took the airbag off but couldn't see the back of this plug. I bought a cruise stalk and plugged it in today but have nothing coming up on dash when I switch it on. Is there anything I can do? Do I need to add the clutch switch?
Got access to under steering wheel looks like my cables are in 1 & 2 so strange why cruise isn't working
Only thing you can do is use techstream to see if the ECU is programmed
if it has, you will see a full list in live data
what colour is the plug on the brake light switch
