X-Touch Software Update?
Ian J R
Hi, any update for my aygo 2019?
18PPDAEU-EA00
86140-YV010
audio - 8.11
os1 - 8.10
os2 - 8.17
Hi @flash22 or anyone else that can help, could I please get the latest updates for my 86140-YV020? Thank you!
Hello, I have an annoying problem with no voice during calls using Android Auto, I've seen someone had the same problem with the same versions I have 😖 Could I get an update please? 🐻
Model ID: 18PPDAEU-EA01  Hardware: 86140-YV020  Audio: 8.10  OS1: 8.10 OS2: 8.14
Hello mr. Flash, can you help me with an update also ?
And i like to install some rear sound, could you help me with a pin-out of this radio for an amp  ?
Hardware: 86140-0H010
Audio: 0830
Besturingssysteem :0621
16890755667896980866924736866643.thumb.jpg.1986f1b9320844c15fe7c89eb1debbfe.jpgHey @flash22 / all,
I'm going in circles trying to find the latest software version for the latest head unit for my Aygo.
I have the 86140 YV020 with the:
Audio 8.10
OP1 8.10
OP2 8.14
Can you help me in finding the update links?
Rav-iv
I noticed there is new firmware available. Can someone PM me? I have the 86140-YV010 model. @flash22? Thanks!
i only have 8.12, whats your current version
99F7C3F1-44BF-4F54-AA00-A0F287B61569_1_102_o.thumb.jpeg.cdbcc472c4a48f4d631bbec1f66e5617.jpeg
Hello,
I recently purchased a Toyota Aygo, and I would like to update my multimedia system with the latest available version.
Can someone PM me ? @flash22 ?
Thanks.
Hi  @flash22 / all
I'm trying to find the latest software update file for my head unit.
Can someone PM me ?
Thanks.
Hi flash22, any update for my aygo 2018?
18PPDAEU-EA00
86140-YV010
audio - 8.10
os1 - 8.10
os2 - 8.14
Thanks.
Hi flash22,
You must be pretty tired of all these 🙂
Have you got an update for my 2016 Aygo:
18PPDAEU-EA01
86140-YV020
audio - 8.10
os1 - 8.10
os2 - 8.14
Thanks in advance!
Hi Flash,
Hoping you can help me out with the attached too...
I've sent you a PM!
10 hours ago, flash22 said:
Your picture is broken
Sorry, something must have gone wrong, hopefully it's visible here:
Thank you in advance!
Hi
 Could I also get the latest firmware please.
Thanks in Advance
Whatsup3009
Hello were can i download the firmware update ?
Thnx for a reply
On 4/18/2023 at 11:59 AM, Ewa said:
Flash22,
I have been testing the 8.12/8.15/8.17 update  for a while and unfortunately have the same problem again. Can't hear the caller.
Is there a newer version that I can update the system to or is it the highest one already?
I also had this problem even with update, and I think I managed to find a solution:
I noticed once that for a split second when someone called me while I was using AA, my screen lit up, and for that split second I heard the call on the Speakers, so:
I entered developer options and turned on "keep screen turned on during charging" - dad called me when I was driving now and I heard him flawlessly 😄 The screen dims heavily after a few seconds when plugged in so it's not distracting (even in nighttime it shouldn't be) and you can click power button to turn off the screen when charging at home for example.
It's a workaround solution but it worked (for me at least - hopefully will help you too Ewa, and anyone who has that problem too)
To enter developer mode tap 7 times on build number in settings (Numer kompilacji in my language), go into developer settings (Opcje programisty) and check Keep screen turned on while charging (Pozostaw włączony ekran)
I can't tell if it's a permament solution, but it seems to work in my case.
Hi.. I have an Aygo from 2014 with the touchscreen. WOuld it be possible to update the software on that car? Would really love if it had android auto, Apple carplay or just some kind of navigation 😛
On 4/18/2023 at 10:59 AM, Ewa said:
Flash22,
Just to follow up, another member jogged my memory
the bluetooth can be tuned with a 4 digit code, i do not have access to an aygo to confirm it, the option should be it the hidden service menu
the button is something like HF Voice quality, under function check
touch2 BT tuning codes.pdf
hi i just changed the radio in my 2016 aygo to the one with 3 buttons and i have a problem with AA. despite the settings on the phone, I can't connect to the radio via usb cable. do i need any update? my radio is: 86140-YV020 8.14 8.34 8.59 @flash22can you help me?
That is current software, did you previously have sat nav ?? if so you need to disconnect the USB from the Nav splitter and plug it directly into the radio
I take you have the Android Auto app installed
20230825_172137.thumb.jpg.f8002f0de15f1cc313dcb4633d04629c.jpgI made a usb with it as you said and now everything works. Thank you and close the topic 😉
Hello all I need update firmware for my touch aygo 2019
MODEL: 18PPDAEU-EA00
Part nr: 86140-YV010
Audio : 810
Syst.1 : 810
Syst.2 : 810
Anyone help me please , thanks in advance!
