Adding auto folding mirror and heated seats
Vins213
Today is the day! Hope so 😆
So the Auris illuminated switch is compatible with the Yaris 3gen, now I'm gonna search the item on various store.
The seats heater are so expensive (about 200€/one), and I have found 2 seats cover heated (back&bottom) for 30€ (Chinese made).
Now I'll search my wiring for autofolding and then I'll see what I have under my seats
i have found some genuine heater elements for €250 for the 4 brand new, i wouldn't trust the Chinese ones not to catch on fire/overheat 😐
Where did you find them?
this is what I bought 😂
The mirrors are aftermaket (pattern part) - try and find a used pair of toyota ones
I can replace my white mirrors cover with the black cover unpainted of the new ones...can I?
The mirror covers, remove the screws behind the mirror then pop it off with a trim tool
this aftermarket mirrors are usually poor quality
Oh...😓
so this one for right side: https://rrr.lt/it/parte/vpb2349-879100db40-toyota-yaris-specchietto-retrovisore-elettrico-portiera-anteriore?sp=87910-0DB40
aaaaand for left side there is no mirror 😔
maybe this: https://rrr.lt/it/parte/jaa1802-toyota-yaris-specchietto-retrovisore-elettrico-portiera-anteriore?sp=Specchietto+retrovisore+elettrico
both have the mirror glass in them, im not sure the red one is a folding mirror tho
I'm gonna write to the shop, the auto folding left side is unavailable on the shop..unlucky!
Are the other items correct?
Wiring needed...821520U860 for left side, 821510U720 for right side...correct?
That's the complete door loom - you only need to add 2 wires per door back to the switch - you can salvage the pig tails (wire and a terminal) from a cheap door loom for less than €20
But how do the mirrors fold after closing car with the remote?
1 wire from the switch to the lock/unlock signal wire in the drivers foot well
as per the first page
U are the best...now I'm gonna post some photos of what I have inside the front door
I'm surprised for what I've found under passenger seat...I didn't found that cable under driver seat or driver/passenger back seats...what is that?
Other photos show what I have for mirrors
IMAGE 2022-04-05 16:34:51.jpg
IMAGE 2022-04-05 16:34:53.jpg
IMAGE 2022-04-05 16:34:56.jpg
IMAGE 2022-04-05 16:34:57.jpg
IMAGE 2022-04-05 16:35:00.jpg
IMAGE 2022-04-05 16:35:06.jpg
1st pic the ribbon cable is for occupancy detection
4  the door loom (HF1) Pins  are mirror fold,  HF1 pin 14 is door lock - i do have conflicting pinouts
5 and 6 are non folding mirror plugs - folding mirrors use 9 pins (10 pin plug)
pic 4  the door loom (HF1 top plug) pin 14 is door lock - HF2 (2nd plug down) Mirror fold/retract is on pins 6 and 12
This for the left door...and for the right? I'm understanding slowly now
Wires TO F74 switch:
- from 3B pin20 blu wire to pin1 (BAT)
- from 3B pin13 grey wire to pin21 (ACC)
- from 3A pin54 yellow wire to F64 pin5>  then green from pin6 F64 to pin11
FROM F74 switch, left side:
- pin10 w/b to pin5 5A
- FL pin6 red to pin12 HF2> then pin10 to H10
- RL pin16 grey to pin6 HF2> then pin11 to H10
- MHL pin17 cyan to pin10 HF1> then pin4 to H10
- MVL pin25 black to pin19 HF1> then pin6 to H10
- M+L pin7 pink to pin9 HF1> then pin5 to H10
FROM F74 switch, right side:
- FR pin5 pink to pin6 GF1> then pin10 to G10
- RR pin15 purple to pin15 GF1> then pin11 to G10
- MVR pin24 light green to pin19 GF1> then pin6 to G10
- MHR pin14 white to pin10 GF1> then pin4 to G10
- M+R pin4 yellow to pin9 GF1> then pin5 to G10
- Lock pin9 rose to pin3 F64> then from pin9 blue to pin14 HF1
H10 is connected to H6 mirror cable and G10 connected to G6 mirror cable...right? I don't understand if I can bypass some wires and weld directly, like the scheme posted a couple of hours ago
I bought autofolding mirrors from eBay, original 9pin early 2019...and I bought the switch from an Auris with 183691 code (84870-02101)
and now the doors wires 🤨
The blue signed ones on the F74 switcher are the wires that I have (on the right the colors of mine).
The red circled are the missing, how can I connect the wires from F74 to H10 and G10 that I don't have?
You need to change the plug for the mirror switch, as the auto folding mirror switch uses the 28 pin connector
Change the plugs or use the existing connectors and swap the 7 pin plug on the new mirrors and run 2 wire from each door for the retract/fold to the switch
