Bolt tight
RHYSF00
I have used this on seized bolts on cars in the past and found it much more effective than WD40.https://www.amazon.co.uk/English-Abrasives-802-10-Plusgas-Aerosol/dp/B0001P02RK/ref=sr_1_3?crid=O7DTAPP38BJK&keywords=plusgas+penetrating+oil&qid=1666208849&qu=eyJxc2MiOiIyLjU5IiwicXNhIjoiMS45MCIsInFzcCI6IjEuNjAifQ%3D%3D&sprefix=Plusgas%2Caps%2C114&sr=8-3
I can see from the photo that it would be difficult to use heat on that bolt. At one time plus gas was difficult to obtain just googled it for you and it looks like it is readily obtainable again leave it to soak as long as poss then apply some more.
I use a 50/50 mix of acetone and ATF (automatic transmission fluid). This is the best penetrating fluid I have ever used, and I've used a few over the years.
It doesn't look very long, is it the same length as the one you had out from the other side?
Will check when weather nice. Think ot 2mm short.
Did you get the bolt out if so how did you do it.
not gotten round to it yet due to work and weather.
It depends on what you want to re-thread.
Could it be for the ABS pick up?
The bolt hole if worst case scenario
14 hours ago, Stivino said:
If there is a 6mm tap in the set it will do.
All fixed. So the bolt head snapped off and we just drilled it and rethread it. Got new bolt in. Car feels smoother
