12v battery maintenance, issues, etc.
FROSTYBALLS
That would be fine 🙂
I have the Noco GB40 which is probably a bit of an overkill...
11 hours ago, Peachysheff said:
t, looking forward to your replies.
Noco GB20 did the job for us today after a period of very little use, so it's a thumbs up from us.
Car parked at Bristol docks for next 12 days so fingers crossed but have a booster lithium Battery in the glovebox just in case.  We’ll see next week!
  • Like 3
Thanks for the replies I have been to Halfords and bought one today so hopefully I can avoid a 2 1/2 hour wait for Toyota breakdown.
  • Like 3
Calcium batteries have some unique features and as a result should be treated differently to normal lead-acid batteries.
However, Lead Calcium batteries need a high-performing, optimised charging system
Don’t Let Lead Calcium Batteries Get Fully Discharged
https://carbatterygeek.co.uk/calcium-battery-charger-silver-calcium-charging/
  • Like 3
Hi all
The car failed me for the first time this week and a new Battery was installed under warranty, I headed over to this forum to see if anyone else had had a  battery problem…😂
What exactly is Ready Mode? Is the car fully started? What is on and what is off in this state?
Many thanks in advance
58 minutes ago, Little Ern said:
Hi all
The car failed me for the first time this week and a new battery was installed under warranty, I headed over to this forum to see if anyone else had had a  battery problem…😂
"Ready" mode is after you have put your foot on the brake and pressed the "Start" button (selector in the "P" position). The word "Ready" actually comes up on the display in front of you. In this mode, the ICE may or may not have started up which will depend on the SoC of the HV Battery and how cold the system is.
Yeah, "Ready mode" basically means the car is On.
On a normal car, it'd be synonymous with the engine started and running, but obviously on a hybrid that isn't such a useful indicator :laugh:
(I still forget to turn the car off occasionally because it's just silent when you stop! It's only when I get out and it starts giving the beeps of shame to remind me it's still on!! :oops:
  • Haha 4
2 hours ago, CPN said:
You and me both! lol!
And me too 😁
  • Haha 2
Ready mode just means it ready to drive regardless of engine running as it will move on just Battery power.
No ready mode then computers have located a problem like a very flat 12 volt system.
Thanks guys, I'm glad it's not just me :laugh:
  • Haha 1
Morning all.
We've had our Yaris GR Sport since early February. It was flawless with no problems whatsoever until early this month, where I noticed the mirrors folding out very slowly and when I got in it it refused to go into ready mode. It was fairly obvious at this point that the 12v Battery was dead.
We do a lot of shorter journeys, with it being a small car, but our driving habits have not changed within the 8+ months we had been using it without issue.
I managed to source a Noco trickle charger and fully recharged the 12v Battery. It has been fine again until today, where the 12v Battery is now fully depleted again. That's just under 2.5 weeks from full charge to dead, and we sat running the car for ~20mins in a car park, last week.
Does this mean the 12v battery could be compromised? I'm pretty unimpressed that it can be fine for ~8 months and then suddenly start depleting at this alarming rate.
I've contacted our local Toyota dealership who were quick to offer help, but after 2 failed call backs from their service department I find myself looking for advice.
I think the "recommended" advice on here is to leave the car in "Ready" mode for an hour and the engine may start two or three times in addition.
With the cooler mornings and change in weather conditions, maybe consider a Battery minder (Ctek or similar) and give it a trickle charge once a week?
As a matter of interest, we've just been away for 11 nights and the car was in an open carpark at Bristol Docks.  Started OK with no issues at all.
Did it this morning and yesterday too.  I wouldn’t have admitted it until I saw your post.  Don’t feel so bad now. 😀
  • Haha 1
With the cooler mornings and change in weather conditions, maybe consider a battery minder (Ctek or similar) and give it a trickle charge once a week?
I'm assuming this was in response to my post, so please correct me if I'm wrong.
I've got it plugged in at the moment, trickle charging.
My main concern is that we've had 8+ months of no issues, and now I have a dead Battery twice within 2.5 weeks.
The usage behavior of the car hasn't changed in any way, which sets off alarm bells in my head. The trips we are making are fundamentally the same as they were, the usage of the car is unchanged.
My main concern is that we've had 8+ months of no issues, and now I have a dead battery twice within 2.5 weeks.
Sorry, should have selected "Quote" 🙄.  It does seem strange about the Battery going flat as its under a year old.  Hopefully the dealer will replace under warranty (fingers crossed).
7 minutes ago, jthspace said:
Sorry, should have selected "Quote" 🙄.  It does seem strange about the battery going flat as its under a year old.  Hopefully the dealer will replace under warranty (fingers crossed).
No worries, I was hesitant to jump in with a response and find out it wasn't meant for me. 😆
The fact it has been fine for a prolonged period of time and is now having issues is leading me to believe it's an issue.
I've contacted the dealer, but it's a sharply different experience once they have your money! 🙄
There might be very small changes that have affected the car but which don't seem significant to you.
That may very well be true, but surely 2 and a half weeks with mild use shouldn't be enough to drain the Battery from fully charged to unable to start?
If that is the case, the 8+ months it has worked fine is then completely polarising to the fact it now won't even last 3 weeks?
I'm not saying you're wrong, but I find it hard to believe that such a drastic difference is down to such minor indifferences in usage.
Chris,  I have no idea how it occurs but 2.5 mild use might be a cause.
The 12v drain will include the start spike, the aircon and wiper motor drain, lights, smart system and, but unlikely,  heated seats and steering wheel.
This is all covered by HV system charging via the DC-DC converter.
Is the system designed such that the HV DC-DC charge covers the whole 12v requirement?  The 12v discharge gradient might be greater than the DC-DC  converter can replace until a number of minutes has passed.  Over a longer Ready time it will cover that initial loss.
There is also another less obvious discharge at the end of each drive (Ready Mode off).
The data module has to upload car data, the route,  fuel and time and the last position*.  This message is limited to 2,000 data points.  The message size for a short journey might be neatly the same as for a long one, but a series of short journeys might cause a larger drain overall.
This is pure speculation but just shows how much things have changed.
*Data logging used to show the route in MY T stopping in the middle of a long journey.   With the update the route is assumed to terminate at the end position.  From the data point end to the journey end is shown as a straight line.
Interesting. Appreciate the informative response, thank you.
The dealer got back to me today and have advised taking it on for a Battery check. I'll be doing that to rule out any fault.
It does seem like my behavior towards usage needs to change, I appreciate that now. I've sat in it this evening for an hour, in ready mode; I'll do this every week, going forward.
This is our first hybrid, so every day is a school day. The main thing that is throwing me is, that it has worked fine for the past 8 months.
If you buy a hybrid car and want to have a 12V car Battery OK, you must:
1/ drive long and often
2/ or recharge often
Smart charging does not guarantee a 100% charge of the car Battery before parking the car for several days.
Jump start is only for quick help
it must not become a regular solution to a problem
For hybrid car users, the best solution is the 1+2 combination
If I park the car for several days - I automatically connect the charger
On 10/25/2023 at 10:17 PM, Dala said:
If you buy a hybrid car and want to have a 12V car battery OK, you must:
Sit in the car in ready mode if you cannot do #1 above.
I will be buying one of these when i get mine -
the cigarette volt meter is excellent for understanding how smart charging works while driving
charging during the day is 14.4V only if the starting voltage is lower than 12.2V
if the voltage at start is higher than 12.2V, the Battery is only maintained at a value of approx. 12.8V during the day
overnight driving always 14.4V (headlights on)
I measured these values on my car
  • Like 3
