Adding auto folding mirror and heated seats
Vins213
3 hours ago, flash22 said:
Well, we got there in the end  👍
I think I have another big problem now, on a new topic 😔
Heated seats
I never looked at the diagrams correctly - while answering another thread, it all fell into place
have a look under the switches by the handbrake, you may find a blue plug with these colours
16526298882697280883952421351808.jpg.598
These wires go into the instrument panel wiring to KF1 in the passenger (LHD) or driver's side (RHD) footwell then go into the body loom it then comes out under the seats in the same 5 pin plug as the seatbelt switch !!!! (if wired)
I had been looking at the wrong connectors all this time, it's been raining here most of the day so not had chance to look at my car
On 5/15/2022 at 7:18 PM, flash22 said:
Heated seats
Yes, I have the same blue plug...I really hoped that I only needed the switcher for the heated seats LOL
Mine didn't have the wiring so I made a loom, also changed the switch led colours, I have some decent quality carbon element heater elements - procrastination means it's on the list of things to be done
  • 3 months later...
Hello there! Winter is coming, and I'm thinking about the wiring and the heated elements to insert over the cushion (and back), like this:
https://youtu.be/d8jE99xXy9U
my front seats do a strange noise, like an old bed with springs (or a door in a horror movie LOL), so I think that I will dismount the seats to fix the noise with some grease
Heated seats
I can confirm, I have the same plug with the same wires...so the wiring of the switcher is there 😄
Still haven't done mine fully, the loom is in and wired, getting to the back of the instrument panel junction box was a pain, passenger seat is done but not wired
Life has taken higher priority this year
Hope you are good, Flash!
Do you have any photos or videos for the installation or the junction? I'm still searching the wire routing for everything
Maybe this one is correct, with 7 green and 8 black from the plug, I suppose is the positive and negative for the light of the switcher
Yours is pre wired, no wiring required just add the switch and fuse the white connectors under the seat will have 4 wires 2 for the heated seat and 2 for the seat belt buckle switch
im sure its all in this thread
sorry if I'm repetitive 😬
I remember that you told me that I need the switcher (easy-to-buy and install), the relay and fuses
the biggest problem is: which fuse (and relay) and where? I wanna buy a kit like THIS (with fuse and relay) and connect it directly to the original switcher...is it possible? What kit do you have?
There is no relay, just 1 standard 15a fuse (S-HTR internal fuse box)
In n°4
What kit can I buy for the installation?
i got mine from a UK seller, a full kit like the aliexpress one but tested before dispatch, the factory switch just does one level, High
The way the high/low works - In low is the bottom cushion only the high is both the back and bottom, with the kits just don't use the supplied wiring/switches, install the elements and connect to the oem wiring
Really? I thought that in L the temperature was colder and in H full power...
So, I need a 15A fuse, the aliexpress kit (which one? The kit with 4 heating pads or the kit with switches to cut?) and the OEM switcher..
Important question: in case of the first kit (only 4 heating pads), how and where I have to join the wires? I really don't understand the K8 and K9 where are
Thanks again Flash, I have to offer you many beers if you are going to spend a few days in Italy
There is no temperature control on the aftermarket ones low turns one heat pad on, High turns on a relay and both pads are on
factory connectors are under the front seats, white plug next to a yellow plug (airbag !!)
i can't find my own pics atm, have a look at this thread
Uhm, ok...so can I buy the kit without the switches? Or the other one with switches to cut off?
I read the post, I'll take the pictures and let's see what's under the seat!
You have wiring up to the seats pins 4 and 5, light green 12v and white/black on one side and light blue 12v and white/black on the other seat
🤩 so I can buy the kit without the switches and join the red wire on kit with 12v to light green (and black to - w/b) and the other 12v to the blue (and - w/b) with a T shape connector...that's right? Much more easy than the folding mirrors 😆
2 heat pads per seat
(+)-------- PAD 1 ----(-)--(+)------ PAD 2 -------(-)
Light Blue is for the passenger side
Light Green is for the driver's seat
