My Norwegen G6r
EXS
Longer and thinner runners improves low end power and reduces high end :P
Hence why Massive ITB Bell mouths give rather ******* low end power.
Which one did you use in the end?
KP
i used the big one on the rigth ;) also adde 260cc injectors from the 1zz engine today and got back some of the mid range power :thumbsup: , my next step will be to take a closer look at the ECU and see if i can tweek it a little
  • Replies 176
  • Created
  • Last Reply
Top Posters In This Topic
  • EXS
    80
  • PaulinhoT
    25
  • Steven252
    14
  • KPARRIS-JONES
    12
It´s sick I tell ya, SICK!!! :D
Love this ultra red color, how did the defuser/splitter come out?
About the hp curve, you should look into 3sgte injectors with that 1zz manifold
I dont remember this by hand after owning couple of these engine but,
Is the 3zz a topmount or sidemount injectors?
thanks guys :)
i honestly don`t know the diffrence between top mount and side mont injectors :unsure: care to specify?
Top mount/feed injectors have the fuel line lead into them from the top of the injectors whereas side-mount/feed have it feeding in from their sides.
The advantages are kinda minimal, side mount seem to seal off better under pressure but it's not something I've really heard people having issues with.
KP
que?
here they are, topfeed?
here you can also see the dìfference between the 3zz (4 holes) ones and 1zz (12 holes) and the more holes the merrier :toast:
thanks mate :thumbsup: good to know
the defuser/undertray came out great, sleak surface and seals up the entire underside of the engine bay.... but i am going to need some air vents to ease up the high pressure that builds up in the motor room when driving at speed, i can almost feel the car catching all that air in the front, but no change in MPG
Looks mighty, can I ask is the induction pipe work your own? if so what kind of filter do you have sat on the end ?
i made the induction pipe my self of regular exaust piping ;)
and i use a apexi air filter (ebay)
  • 2 months later...
I like these wheels, but preffer the white ones, how big are both, as I'm thinking of replacing my MiMs and getting some 17" Sparcos..
I think it looks fantastic :drool: .Nice to see a facelift E11 modified for a change too :yahoo:
thanks mate :)
Do you get any rubbing with 18" as I'm thinking of going in that direction...
  • 5 weeks later...
not generally but some at full wheelturn a little rub in the inner fender
